Hi Ryan,
Are you allowed access to Report Administration to export a .rptdesign? If you can export your created QBR reports as a starting point for further enhancements. Also, does the SaaS allow access to a Demo or Development database? You would only need Read Only access to a development database to do 90% of report development or customization. If you can export, the out of box reports are always a great starting point for the reports. But remember the out of box .rptdesign files are the only copy. Make a copy of the .rptdesign and rename it before you start digging in for changes.
Another tip; Work Order Details report, woprint.rptdesign, is the best report design for examples of cascading parameters, use of 'where' clause, and format/layout of Maximo/BIRT reports.
NORMA RAMEY
