Maximo Crews & Graphical Crew Management
  • 1.  Maximo Crews & Graphical Crew Management
    Posted 12-13-2024 19:35
    Crews / Person Availability
    Were currently implementing crew functionality and we are intending on heavily using, modified person availability which will be interfaced from a 3rd party system called Time2Work. The issue I am facing is that when checking the Crew assignment status for a specific day, it doesn't seem to count modified availability which is set to 'Working Time', although it does count for 'non-working time' e.g. vacation / sick. I have found a sneaky workaround where you can add negative non-working time which actually then shows as available working time when checking the crew assignment status. Just wondering if anyone has ran into this issue before.
    Graphical Crew Assignments
    When using the Graphical Crew scheduler application, I only seem to be able to make the assignments when I toggle to day view, when in the week view, I cant make the assignments, although it looks the same and seems like you should be able to select multiple positions and assign to a labor. Any thoughts
    #Scheduling
    joseph davies
    Cohesive
