Visibility into Add-On Products Reserving AppPoints
  • 1.  Visibility into Add-On Products Reserving AppPoints
    Posted 02-24-2025 08:12
      |   view attached
    Have you ever wondered how MAS Install AppPoints are tracked? Check your SLS database, in the licenses table.
    Spatial for example gets two entries with the licenseeId="spatial" to reserve the AppPoints. One entry has a productid of MAS-Add-On-Premium and the other MAS-Add-On-Limited. These respectively reserve 15 and 5 AppPoints to reserve the 20 required AppPoints for a Spatial install.
    Phil Runion
    Projetech
