Maximo Inspections (Work Center) have been out for a while now and I wondered how folks are handling the reporting of the completed results? I know you can see them in the work center, and get to that via the work order as well as other places. However, that is a slow and inefficient way to do it. There is no option from there to save (or print) the inspection result except for standard browser controls. Some customers are asking for all inspection results to be automatically saved to PDF and stored.
Is anyone using BIRT or Cognos to report on inspection results? What about external reporting tools?
Is there a way to take into account the dynamic nature of the inspections? By this I mean is it possible to create a report that will only render the fields that were populated, ignoring any blanks through being optional or not used in the conditional responses feature? Also, is it possible to create a report that can be used for multiple inspections by, I assume, identifying the Inspection Result ID and then dynamically rendering the INSPQUESTION and INSPFIELD attributes that have data in them.
I may be asking for too much but the alternative is to have a 1:1 relationship between reports and Inspections (could be hundreds in time), and a need to modify both whenever the Inspection changes. Plus, any inspection that makes heavy use of the optional and conditional responses features would contain a lot of blanks.
Any and all discussion on the subject welcomed!
#Reporting#WorkCenters#WorkManagement------------------------------
Graham Drinkwater
Vetasi
