issue was related to the Sigoption RELOBJSTR Missing For RSCONFIG Application, which allows the users to select a Object Structure to set up a portlet. Once the steps to add the sigoption were taken, the Download button was working fine.
See the below article on how to active the missing sigoption it is hidden on core maximo.
Please see below article on how to activate.
https://www.ibm.com/support/pages/sigoption-relobjstr-missing-rsconfig-application
Have to rebuild all start center portlets after applying the above.
Needs to have object structure populated for download button.
Can not edit the object structure on start centers, limitation in Maximo.
Diane Nohner
City of Minneapolis
Sent: 05-04-2021 16:03
Subject: Start Center Portlet- download/export button - Activate
Remember to make sure to choose a report object structure for your start center result set.
If you don't have any, then you will need to go into the Object Structure application to create one.
After a little digging, I found a link that walks through the process here: How to configure a Result Set portlet in Maximo 7.6
There is also a video that shows the feature in use at Start Center Design Basics - Roles & Performance and you will probably want to skip forward to about 52:45 in the video for the example.
Result set configuration: How to configure a Result Set portlet in Maximo 7.6
| Ibm |
remove preview |
| How to configure a Result Set portlet in Maximo 7.6 |
| How can you configure a Result Set portlet in Maximo 7.6 and how can you add a dot notation/joined attribute through a relationship? |
| View this on Ibm > |
