Maximo Graphical Scheduling
  • 1.  Maximo Graphical Scheduling
    Posted 14 days ago
    On graphical scheduling application within Gantt view we need to make few date fields read only for all schedules and also remove date lookups.
    Can anyone help on this which setting or properties changes needs to be done to archive this.
    Thanks in advance.
    #Scheduling
    PB
    CTS
  • 2.  RE: Maximo Graphical Scheduling
    Posted 13 days ago
    Hi Prashant,
    Electra Learning can help you with this. It would be best to contact me directly at neil@electralearning.com
    Neil
    Neil Summers
    Electra Learning
  • 3.  RE: Maximo Graphical Scheduling
    This message was posted by a user wishing to remain anonymous
    Posted 13 days ago
    This post was removed
  • 4.  RE: Maximo Graphical Scheduling
    Posted 13 days ago
    Hi Prashant
    There are 2 ways this could be done:
    1 - Modifying presentation XML file to set inputmode="readonly" for fields that you would like to be read only.
    2 - At Java code level, if you need more elaborate rules, e.g. Making a field read only, if a certain condition is met.
    Lori Pilgrim
  • 5.  RE: Maximo Graphical Scheduling
    Posted 10 days ago
    Hi Prashant.
    Before coding Java or changing presentation XML, you could give a try to Global Security Restrictions or Security Groups restrictions for more granularity.
    Daniel Torrescusa
    Piensa en nube
