  • 1.  Automation Scripts
    Posted 11-19-2021 04:13
    Hi Folks
    I'm more familiar with SQL than I am python, would appreciate it if someone could help me out with the correct syntax for the bolded section for my automation script, thanks in advance
    Cheers
    if mbo.isNull("GLACCOUNT"):
    errorgroup ="WORKORDER"
    errorkey = "GLAcctIncomplete"
    else:
    mbo.getString("GLACCOUNT") like "%-??????"
    Peter McDonald
    Prima58
  • 2.  RE: Automation Scripts
    Posted 11-22-2021 08:58
    FYI - I'm new to automation scripts too. I found this quick reference guide helpful (although I don't think it helps you with your current question).
    https://bportaluri.com/sdm_downloads/automation-scripts-quick-reference
    User 1972
  • 3.  RE: Automation Scripts
    Best Answer
    Posted 11-22-2021 09:13
    Maybe something like this?
    elif mbo.getString("GLACCOUNT").find("-??????") > -1:
    Hope this helps,
    Alex Walter
    A3J Group, LLC
  • 4.  RE: Automation Scripts
    Posted 11-22-2021 17:06
    Hi Alex
    Thanks for your feedback, this worked perfectly for my needs, appreciate it
    Cheers
    Peter
    Peter McDonald
    Prima58
  • 5.  RE: Automation Scripts
    Posted 11-22-2021 09:18
    If you're really sure you want to throw the same error for both conditions, simplify it with:
    # Declare a variable for the value of the GLACCOUNT attribute
    glAccount = mbo.getString('glaccount')
    if glAccount is None or glAccount.endswith('-??????'):
        errorgroup = 'WORKORDER'
        errorkey = 'GLAcctIncomplete'​
    Otherwise:
    if glAccount is None:
        # make a different error message for this
        errorkey = 'GLAcctIsNull'
    elif glAccount.endswith('-??????'):
  • 6.  RE: Automation Scripts
    Posted 11-22-2021 09:43
    Also...a cleaner way to through an error is to use the service.error() method...
    service.error("ERRORGROUP, "ERRORKEY", [params]);
    Jade Warren
    Great River Energy
  • 7.  RE: Automation Scripts
    Posted 11-22-2021 21:23
    you might be able to use
    elif mbo.getString("glaccount").endswith("-????")
    Jeff Kish
    interloc solutions
