Hi all I am facing one strange issue in java
I am getting the set from mxserver after doing set where and reset I got count of set let's say 7 then I am traverssing using for loop
MboSetRemote assetSet = mx.getMboSet("ASSET", userInfo);
assetSet.setWhere(my where clause)
assetSet.setOrderBy(classstructureid)
assetSet.reset()
if (not assetSet.isEmtpy())
for (Int i= 0; (assetMbo= assetSet.getMbo(i))!= Null; i++)
if()
else{
if()
But when loop traverse it works fine for first 3 records it is working fine as soon as 4 the record loop mbo is coming null.
Is it because of memory issue ? Or in debugging where or how can we know that why mbo is coming null which shouldn't be null as we have 7 records in set
#Customizations------------------------------
Sahil Dutta
xyz
