  • 1.  Locations with only 1 asset
    Posted 11-01-2021 10:25
    Edited by Christopher Winston 11-01-2021 11:52
    Hi, when I create a WO for a LOCATION that has 1 asset assigned to it, it automatically uploads the asset on the WO.  Is there a way to avoid that? I just want to create the WO against the LOC code (not the asset). I know the obvious is to just delete/remove the asset ID but it seems to be tedious to keep doing that on multiple work orders.  The other solution I am aware is to create a second "dummy" asset to the LOCATION but I end up with a large number of records that are fake assets.  Any other solution you can suggest would be helpful and highly appreciated. Thanks in advance.
    Roberto Landero
    PRIDE INDUSTRIES
  • 2.  RE: Locations with only 1 asset
    Best Answer
    Posted 11-02-2021 09:12
    Hi Roberto,
    You can disable that functionality by folowing this post from Bruno Portaluri
    Regards
    André Cordeiro
    AQUASIS
  • 3.  RE: Locations with only 1 asset
    Posted 11-03-2021 14:10
    Yep, this script works perfectly to address the concern.
    Megha Tatiya
