It is possible to revise, but it's restricted as it definitely isn't always the best practice. Essentially, when you revise you are stuck on the same revision of the contract. So if you increased the amount of the contract for example, you wouldn't be able to use those additional funds on the existing POs. But there are other reasons to revise a PO so Maximo allows you to still revise the PO if necessary.
To revise a PO that has a contract revision, you have to check a checkbox on the PO (attribute is IGNORECNTREV, title is "Bypass Contract Revision on PO Approval"). If you have security permission for the option, it will be displayed right below the SITEID in the PO application out of box. Checking that will allow you to approve a revision even if the contract has changed, provided that other criteria (such as sufficient funds) are still met.
Projetech
