I assume you allready followed
http://www-01.ibm.com/support/docview.wss?uid=swg21672201 (i think you have partly done that - cleared cache part) , but don't know if you also deleted contents of :
- profile_root/temp/
- profile_root/wstemp/
- profile_root/config/temp/
Also, what are timestamps on dmgr & dgmr, which one is current one? One could be leftover of previous configuration attempt.
Janez Naglic
KOPA d.d.
Sent: 03-17-2022 06:24
Subject: unable to start deployment manager websphere 8.5 in linux
I found 2 folders in directory /opt/IBM/WebSphere/AppServer/profiles/Dmgr01/logs by name
dmgr & dgmr when i started node. folders dmgr & dgmr contain startServer.log. how come this folder dgmr created.
syed mehdi
kng
Sent: 03-16-2022 10:45
Hi, you could try to check server.xml file for possible file corruption or compair it with test environment (if exists) or if backupconfig od dmgr profile had been done before.
in path
/opt/IBM/WebSphere/AppServer/profiles/Dmgr01/config/cells/knguserdataCell01/nodes/knguserdataCellManager01/servers/dmgr/server.xml
Regards, Janez
Janez Naglic
KOPA d.d.
Sent: 03-16-2022 02:57
Dear Siva,
yes i tried number of times.
syed mehdi
kng
Sent: 03-15-2022 09:58
Dear Syed,
Have you tried to reboot the webepshere server's physical machine and restart the DMGR and Nodeagent? .
Siva Kumar
Ibm
Sent: 03-14-2022 06:03
Dear Prashant Bavane,
No PIDs i found related to JAVA also i restarted and try again but everytime when i try startManager.sh or startnode.sh a new entry of com.ibm.ws.runtime.WsServer is found in native std out file.
Why this entry keep on generating.
syed mehdi
kng
Sent: 03-09-2022 08:43
It is possible that there are java processes hung due to multiple attempts to start like starManager.sh.
you can try finding java processes related to your Dmgr using GREP and keep on force killing those PIDs until you dont find any new pid and then after that try running startManager.sh/
Prashant Bavane
CTS
Sent: 03-08-2022 01:39
I have attached files.
syed mehdi
kng
Sent: 02-28-2022 06:02
Inside the log folder can you see pid file? have you tried deleting it?
Also check systemout.log inside dmgr folder to see what errors it is throwing.
EAM360
#IBM Champion 2022
Sent: 02-28-2022 02:12
hello,after sudden shutdown of linux server,
unable to start deployment manager websphere 8.5. when i gave command startManager it is fail to start and not much information given in startserver log.
#ServiceProvider
syed mehdi
kng
