Two things we did to make this work:
1) Since for us, our most important "Assets" are our buildings/facilities, every Location in the Locations table has a matching Asset. This would enable us to put data in like "this carpet Item record is used on this floor of this building" (carpet isn't used on what Maximo would traditionally call an Asset).
2) In Database Configuration, I created a custom relationship:
OBJECT: Item
CHILD OBJECT: Sparepart
WHERE CLAUSE: itemnum = :itemnum and itemsetid = :itemsetid
After that, it was pretty much just copy the XML from the Inventory application's Where Used tab, paste it into the Item Master XML at the right spot, and make sure to change the relationship on the Table Properties for the "Where Used" child table.
The only 'gotcha' I can see in this is that Inventory is at the Site level but Items are at the ItemSet level, and this is why I had to use a custom relationship -- to remove siteid from the Where Clause. For us, we only have 1 Org and 1 Site in Maximo, so it was not a problem. If you have multi-Orgs or Sites, you may have to do something more to get it how you need it.
