  • 1.  How do I remove extra assignment lines on a work order?
    Posted 09-15-2020 18:52
      |   view attached
    If I accidentally add a new row in the Assignments tab of a work order, how do I remove this row? There is no trash can at the end like labor records, materials, and other records. I have attached a screenshot to this record for reference of what we are seeing.
    Anne Antonelli
    Attachment(s)
  • 2.  RE: How do I remove extra assignment lines on a work order?
    Posted 09-16-2020 07:49
    Yeah we found this really strange too without any obvious explanation aside from they forgot to put it in. The good news is adding the table column via application designer is pretty quick to implement and still enforces the same validation logic. To add the trash can, you just drag a new table column on to the table and set it as follows:
    Type: Event
    Event: toggledeleterow
    Event Description: Mark Row for Delete
    Event Icon: btn_garbage.gif
    Projetech
  • 3.  RE: How do I remove extra assignment lines on a work order?
    Posted 09-16-2020 10:31
    Additionally, it is resolved in 7.6.1.2 and described as:
    In the Work Order Tracking application, the Delete Assignments icon is not displayed.
    Projetech, Inc.
  • 4.  RE: How do I remove extra assignment lines on a work order?
    Posted 11-07-2023 10:07
    It appears that the Assignments tab lacks a direct deletion option for added rows, unlike labor and materials records. To remove an accidental row, consider clicking on the row itself, which might activate an editing or removal feature.
    Aaronn78 Khan
    google
