  • 1.  After upgrade from 7.5 to 7.6.1.1 some Rich text controls are disabled.
    Posted 10-06-2020 08:38
    The create link and insert image are grayed out in all apps. Has anyone else run into this? I am not seeing where I can enable them and it is probably right in front of my nose.
    Thx.​
    Wes Williams
  • 2.  RE: After upgrade from 7.5 to 7.6.1.1 some Rich text controls are disabled.
    Posted 10-07-2020 08:02
    ​Well it is looking like Edge may be part of the problem. I am able to add links although it is a convoluted process.
    Wes Williams
    Northrop Grumman
  • 3.  RE: After upgrade from 7.5 to 7.6.1.1 some Rich text controls are disabled.
    Posted 10-07-2020 09:18
    That's really interesting and not sure I've seen that before. There was an Edge/IE fix in 7.6.1.1 IFIX 05 related to text size in the rich text editor, but I didn't see anything about certain controls not working.
    Out of curiosity I assume you're talking legacy Edge and not the Edge that is based on Chromium (the open source portion of Chrome)? I tested in some of our environments (even back to 7.6.1.1 base with no IFIX) and seemed to work just fine for me in those with the new Edge. Unfortunately the legacy Edge is removed when you get the update so I don't have a way to test that. Officially the new Edge isn't supported until 7.6.1.2 of Maximo but because it's based on Chromium it functions the same as Chrome so works well on versions that support Chrome.
    Projetech
