  • 1.  PM Work Type
    Posted 10-06-2022 12:57
    In Maximo's PM application I noticed inclusion of work types 'CM' and 'EM'. I understand these are expected to be used on meters based PM's (not on time-based PM) but can anyone in this forum give me some practical examples where the preventive maintenance work order generates a corrective or emergency type work order.
    Thanks in advance
    #Scheduling
    Ashok Fernandes
    EMA, INC
  • 2.  RE: PM Work Type
    Posted 10-06-2022 16:18
    Hi Ashok,
    I believe the PM application simply shares the same worktype domain you build from organizations -> work order options -> work types.  That being said, in Condition monitoring, you can set up your monitoring point to create a work order from a PM rather than a job plan.  If you were creating a corrective or emergency work order from a meter reading being monitored in condition monitoring, the PM you choose to create the work order having those work types would be the best reason I could think of.
    Welcome to hear anyone else ideas on this.
    thanks!
    Eric Godel
    Eric Godel
    Bay Systems Consulting
  • 3.  RE: PM Work Type
    Posted 10-07-2022 08:13
    Thanks Eric, Now it does make sense. I did not consider the predictive maintenance aspect when looking at those values.
    Ashok Fernandes
    EMA, INC
  • 4.  RE: PM Work Type
    Posted 10-07-2022 09:01
    One other thing to consider is Condition Monitoring as you can link a condition to a PM.
    I know the app is called "Preventative Maintenance" and really all it is a "Work Order Generator" and the Work Type is simply one way of categorizing the Work Order being generated.
    Mike
    Michael Marsonet
    OSV Advisory Inc.
