SR Module takes between 1-2 minutes to open a SR Record from both the find service request and list tab.
It loads the SR list in a timely manner when you select a SR # is when it takes between 1-2 minutes to load.
Steps taken to resolve
updated statistics and refreshed index tables
imported out of the box xml file.
Have a case open with IBM support and are stumped.
This is the only module with the issue all others function as intended.
This started after upgrading to Maximo 7.6.1.1
System Information
App Server IBM WebSphere Application Server 8.5.5.14
Version
Tivoli's process automation engine 7.6.1.1-IFIX20200522-1523 Build 20190514-1348 DB Build V7611-365 HFDB Build HF7611-13
IBM Maximo Asset Management Work Centers 7.6.0.4 Build $build$ DB Build V7604-119
IBM Maximo Asset Management Scheduler 7.6.7.3 Build 20190514-1348 DB Build V7673-78 HFDB Build HF7673-12
IBM Tpae Integration Framework 7.6.1.1 Build 20190419-2330 DB Build V7611-01
IBM Maximo Spatial Asset Management 7.6.0.5-20200127-1155 Build 20190522-1410 DB Build V7605-09 HFDB Build HF7605-06
IBM Maximo Asset Management 7.6.1.1 Build 20190514-1348 DB Build V7611-01
IoT Connection Utility 7.6.0.2 Build 20190426-2206 DB Build V7602-07
Server OS Windows Server 2012 R2 6.3
Server DB Microsoft SQL Server 13.0 (13.00.4435)
#EverythingMaximo------------------------------
Diane Nohner
City of Minneapolis
