Tim,
Here are the core scripts for performing the printing actions. The project has all the documentation and examples of printing from the Automation Script directly without an additional libraries.
https://github.com/sharptree/zebra-printing-scripts
Jason
Jason VenHuizen
Sharptree
Sent: 09-21-2023 06:53
Subject: Zebra Label Printing from Maximo
Jason
My current client is on MAS 8.10 but hosted by IBM and IBM refuses to install the Zebra library on our MAS instance. So we are working on automation scripts to send ZPL code directly to an IP address just to test whether it works. After that we will work on selecting printers etc.
Your script seems to do exactly what we are attempting to do, but does your script rely on the zebra library to have to be installed on the server?
Tim Bartmann
Self
Sent: 04-07-2022 11:59
We have published a solution for printing Zebra labels from Maximo. This has a full Maximo 7.6.1 / MAS 8 compatible installation and deploys in a few minutes. We also provided an uninstaller in case you want to pull it out.
Hopefully this is helpful to you all and if you have questions feel free to reach out.
GitHub - sharptree/zebra-printing-scriptsGitHub | remove preview |
| GitHub - sharptree/zebra-printing-scripts | The Zebra Label Printing automation scripts provide the ability to define uniquely identified printers and labels, and then print labels by providing the printer and label names as well as a object name and object unique identifier. | View this on GitHub > |
Jason VenHuizen
Sharptree
