Using OSIN automation script with Rest API
  • 1.  Using OSIN automation script with Rest API
    Posted 04-12-2023 12:34
    Good day everyone!
    We have a working OSIN script before that was using SOAP XML/Web Service for inbound transactions. We decided to migrate to Rest API, hence we are now using JSON. My question is that is there a way to parse the JSON that we are sending from POSTMAN/RestApi to Maximo? Since we changed the structure to RestAPI, we are getting json not supported error when the OSIN script is enabled. It is pointing out to the line that has ctx.getData(). I'm trying to use stringify or parse but they arent seem to be working or the syntax could be wrong. Any help is much appreciated, thank you.
    KM Cornista
