  • 1.  Mass Update
    Posted 01-27-2021 10:40
    Good morning All,
    Could anyone please advise How can i able to do the mass update the "Sub-Elin" and "Customer Code for PM work orders in Maximo. Thank you!
    Kind regards,
    Peter
    Pitamber Parajuli
    Vectrus Systems Corporation
  • 2.  RE: Mass Update
    Posted 01-28-2021 09:42
    Name of the fields look like custom. Could you please focus your mouse pointer in these fields and press Ctrl+I and let me know the details.
    If you have access to database, please update directly
    SIVATHANU SIVAKUMAR
    Saudi Railway Company
  • 3.  RE: Mass Update
    Posted 01-28-2021 14:32
    I agree with the first reply, these appear to be custom fields, and you'll need to first identify the real field name rather than the label in the UI. Once you've done that you could use Actions and an Escalation to perform these updates if you don't have the option to perform a database update directly. I have a Blog post on the topic here: https://www.webuildits.com/bulk-data-updates-with-actions-and-escalations/
    Tim Ferrill
    Intelligent Technology Solutions, LLC
  • 4.  RE: Mass Update
    Posted 01-29-2021 20:15
    There are a number of ways to do the bulk update regardless of whether they are custom or standard fields.  The two most available is to use the MX Loader and the application export/import.  Then you have OSLC, the MIF and SQL.
    ISW
  • 5.  RE: Mass Update
    Posted 10-31-2021 07:12
    I have just published a post on my blog to describe how to implement a mass updated function.
    Hope this is what you are looking for: MaximoDev - Maximo bulk update from List view (bportaluri.com)
    Regards
    Bruno Portaluri (MaximoDev)
