I'm assuming you don't have custom code that would trigger cache reloads, that the problem you are seeing is from supportable use of the product. As such, I would raise and work through a Support Case with IBM about this, in an effort to "make it better for the next guy."
If you should end up having to make the column bigger on your own, you won't be able to do it through the UI, because SERVERSESSION is flagged as Internal. That would mean you have to turn to SQL or DBC scripting to change it.
Jason Uppenborn
Bentley Systems
Sent: 11-25-2021 02:49
Subject: ORA-12899 :value too large for column MAXIMO.SERVERSESSION.RELOADCACHE (acttual:1028 maximum :1024) .
Dear Experts,
Please note that , In our production environment some times users are getting below error while routing the work flow and some time saving the record.
Our production environment is cluster environment. So can we increase the length of the reloadcache to 2048 , So that it will allow more text for caching .
Can it be any issue in the caching mechanism ?
As per my knowledge reloadcache frequently get updated in cluster environment to synch the other members.
Alok
Alok Pattnaik
Praxis Solutions
