  • 1.  Maximo inbound integration
    Posted 10-06-2020 08:15
    We have a scenarios where inbound cost management data being sent from external system , this data wont have any specific values for orgid and sited but within maximo we maintain domain to devise siteid,orgid for this inbound data based on one value within the message being sent. But as we can map to multiple sites and organization for one inbound message how can be have
    1. insert the records multiple times for each orgid/sited
    2. udpate in case recrod exists for all of them
    we are trying to add this logic at Object Structure or Enterprise service layer automation scripts
    Its Maximo 71.6.1.2
    Kindly suggest as we are getting incorrect number of records being inserted with combination of beforeCreateMboSet(ctx) and preSaveRules methods at OS layer
    Thanks in advance.
    PDB
    Google
  • 2.  RE: Maximo inbound integration
    Posted 10-19-2020 13:37
    Hi Prashant,
    This is a great question! @Alex Walter or @Steven Shull - do you have any thoughts on his question?​​
    Annie Moncure
    Projetech
  • 3.  RE: Maximo inbound integration
    Posted 10-19-2020 18:50
    Prashant,
    I'm not exactly sure what the issue is. Can you explain what the before/after scenarios are and what the code needs to do to properly handle the org/site data?
    Alex
    Alex Walter
    A3J Group LLC
  • 4.  RE: Maximo inbound integration
    Posted 10-20-2020 02:59
    Hi Alex,
    SAP sends one record and it has ABC value from which we identify within maximo how many site/org combination we need add data sent by SAP 1 rwo into multiple records
    and its causing some glitch in code and inconsistent
    Prashant Bavane
    CTS
  • 5.  RE: Maximo inbound integration
    Posted 10-20-2020 15:12
    Hi Prashant.
    It seems like Multiplication Control in Enterprise Services provides the functionality you are looking for. If you have a more complex logic, then Automation Scripts would likely be the best way to accomplish it.
    Could you elaborate on the behaviour you are getting using automation scripts?
    Daniel
    Daniel Torrescusa
    Piensa en nube
  • 6.  RE: Maximo inbound integration
    Posted 10-20-2020 21:11
    Hi Daniel,
    Thanks for sharing this. I didn't know about this multiplication control.
    Learnt something new! Great to see the amount knowledge that is shared in this community and IBM's Maximo community.
    Thanks again!
    Biplab Choudhury
    Tata Consultancy Services
  • 7.  RE: Maximo inbound integration
    Posted 10-20-2020 22:58
    Thanks Daniel.
    I have tried multiplication control but did not get successful may be i ma mission on something.
    Alex to clarify  more :
    e.g. Asset recrod details sent by external system as one record without any siteid and orgid information.
     Now external system send one column XYZ for asset record , for which we have a domain in maximo which has combination of xYZ adn SIT ORGID.
    One XYZ value can result into multiple SITID ,ORGID and hence we need to create and udpate(if already exists) asset for all eligible SITEID ,ORGID combinations.
    We have done automation script on object structure and in beforeCreateMboSet handled few transformation on data sent by external system and in preSaveRules tried logic to create multiple assets using asset mbo set fetched via MXServer and filters to check if matches/exists and update else add for eligible combination.
    Result is weired on some iteration when inserting new it creates accurate number of recrods on other not
    Prashant Bavane
    CTS
  • 8.  RE: Maximo inbound integration
    Posted 10-21-2020 06:00
    Hi Prashant.
    I think you can do what you need with automation script in beforeCreateMboSet:
    1. Get data from external system using context object to obtain XYZ column.
    2. Create your MboSet with Mbos per SITEID, ORGID combinations attending to XYZ value.
    3. Set that MboSet on your context object to be processed by MIF. If message type is Sync, it should update existing Mbos and create the new ones.
    With this approach you wouldn't need preSaveRules function.
    Daniel Torrescusa
    Piensa en nube
