The CLASSSTRUCTUREID is normally not shown within the application, so that part of the screen has been changed.
As for you wanting to change a primary key field, the answer is
no, not once the record is saved except by using an SQL statement, not a technique I'd endorse.
I have altered my screen to display the field and yes you can on creation, alter the autonumber to use PV_INV as per your example.
This is a use case I would NOT encourage.
I would like to explore further why you have exposed the field and are wanting
not to use the autonumber.
There is only one use case where I have needed to find the CLASSSTRUCTUREID for data loading, in all other cases I have used the HIERARCHYPATH instead, The HIERARCHYPATH though for a number of objects needs to be included as it is a non-persistent field in the object and usually, these are not included.
ISW
Maximo Practice Manager
eMail:
#IBMChampion2021
Sent: 11-09-2021 01:22
Subject: Classifications
Hi Craig Kokay,
As an example, you may refer to photo below. Is there any possibility how we can amend Class Structure from photo below? Let say I want to amend it from 1124 to PV_INV.
Nor Herman Afandi
Sarawak Energy Berhad
Sent: 11-05-2021 09:03
Hi Herman,
Hmmm, the CLASSSTRUCTUREID is generated by Maximo, so not sure what you're trying to achieve. Can we get some more detail as there maybe something else that can be changed instead of a readonly field.
ISW
eMail: ckokay@isw.net.au
IBM Champion 2021
