Diane, I see a couple of options here . . . some requiring more keystrokes than others, so the business benefit-effort needs to be considered.
- As Frederic mentions below, you could change the 'support-assets' to rotating tools and add time for them on the Actuals tab of the work order similar to Labor
- On the 'fix-the-machine', add one or more child work orders that are associated with support-assets. The child WO(s) would be associated with the support-asset as a work order hierarch
- All actuals (time, material, etc.) charged to the child support WOs would roll up to the parent and this would create good history records to report on
- On the 'fix-the-machine' work order, add one or more job operations for the support-assets (the asset on a job operation can be different between the parent WO and the job operation).
- This would have the benefit of including support-assets time on the parent WO although the time reporting would be a labor transaction.
- Not sure of your Maximo version but you should be able to add the support-assets to the Multiple Assets and Locations table of the primary work order. The disadvantage here is that the time worked by the support-assets can't be individually tracked. This would just reflect the fact that the support-assets were related
Option one is probably the cleanest as the support-assets are truly tools. Converting to tools may require some painful master data revisions. My favorite is option two which could be implemented with existing data.
Good luck!
Mack Parrott
Sent: 10-05-2021 01:43
Subject: Assets used in Mainttennce
I am looking for some help on the best method to address a situation we have. I have done some searching and cannot find a solution. Scenario: we have large assets like bulldozers, tractors, hoists, generators, etc. all of which are assets themselves. Some of these assets are actually used to do maintenance work on other assets. At times multiples. So we have a WO to do maintenance on Asset 1. Asset 2 and 3 are used to perform the maintenance on Asset 1. We want to log the time each of Asset 2 and 3 was used in performing the maintenance on Asset 1. In the past, they have been using the asset field on the Actual Labor row to log this time OR were putting it in a Work log (which is impossible to report against). My question is, is there a better way to track the time on Asset 2 and 3 besides using the asset field on the labor row? |
Diane Carr
PAE
