I have seen some folks apply the 7.6.1.2 feature pack only and then not see the new Scheduler applications. Because there are new applications with Scheduler 7.6.8, a new install key is required so if that part of the upgrade was missed, you won't see the new applications. Do you see Graphical Resource View or Scheduler Data Manager? Those are also new applications.
Lacey Lurges
Sent: 09-28-2020 08:35
Subject: MX 7612 Scheduler 768
Thanks Lacey, I suppose I shouldn't, but I assume our folks installed correctly, since I have all the other Scheduler apps, just not GWW. We'll keep an eye out for the iFix.
Kevin Hutson
NAES Corporation
Sent: 09-26-2020 08:05
Also, iFix 001 is coming out next week and there are some fixes for Graphical Work Week such as fixing the filter in the top section. I highly recommend applying it :)
Lacey Lurges
Sent: 09-26-2020 07:56
Hi Kevin,
Did you follow these instructions too?
You have to download Scheduler 7.6.8 and run the Installation Manager so you see the new applications.
https://www.ibm.com/support/pages/node/6224048
Lacey Lurges
