  • 1.  MX 7612 Scheduler 768
    Posted 09-25-2020 15:34
    After upgrade to new Scheduler and granting permission for the Graphical Scheduler apps, no access to Graphical Work Week, in the GoTo > Planning and Scheduling.  Is anyone else having this issue?
    #Scheduling
    Kevin Hutson
    NAES Corporation
  • 2.  RE: MX 7612 Scheduler 768
    Posted 09-26-2020 07:56
    Edited by Lacey Lurges 09-26-2020 07:57
    Hi Kevin,
    Did you follow these instructions too?
    You have to download Scheduler 7.6.8 and run the Installation Manager so you see the new applications.
    https://www.ibm.com/support/pages/node/6224048
    Lacey Lurges
  • 3.  RE: MX 7612 Scheduler 768
    Posted 09-26-2020 08:06
    Also, iFix 001 is coming out next week and there are some fixes for Graphical Work Week such as fixing the filter in the top section.  I highly recommend applying it :)
    Lacey Lurges
  • 4.  RE: MX 7612 Scheduler 768
    Posted 09-28-2020 08:36
    Thanks Lacey, I suppose I shouldn't, but I assume our folks installed correctly, since I have all the other Scheduler apps, just not GWW.  We'll keep an eye out for the iFix.
    Kevin Hutson
    NAES Corporation
  • 5.  RE: MX 7612 Scheduler 768
    Posted 09-28-2020 09:10
    I have seen some folks apply the 7.6.1.2 feature pack only and then not see the new Scheduler applications.  Because there are new applications with Scheduler 7.6.8, a new install key is required so if that part of the upgrade was missed, you won't see the new applications.  Do you see Graphical Resource View or Scheduler Data Manager?  Those are also new applications.
    Lacey Lurges
  • 6.  RE: MX 7612 Scheduler 768
    Posted 09-28-2020 09:20
    I see all the other Scheduler apps, just not GWW
    Kevin Hutson
    NAES Corporation
  • 7.  RE: MX 7612 Scheduler 768
    Posted 09-28-2020 09:42
    If you confirm the IT folks did follow the directions to install Scheduler 7.6.8 and your Security Group does have access to Graphical Work Week then I would open a support Case.  The Scheduler support folks are great.
    Lacey Lurges
