  • 1.  SQL Server Full-Text search giving me strange results
    Posted 05-03-2022 16:16
    SQL Server 2012, Maximo 7.6.0.8
    In Item Master (and Inventory), I'm doing a search on the Description field (which is configured for Full-Text Indexing) for:
    12 green​
    and I get results such as these:
    Spray Paint, Sherwin-Williams Krylon, #2001, Decorator, Interior/Exterior, Hunter Green, Finish: Gloss, 12 oz, Aerosol Can
    Handle, Threaded (3/8" Male), Telescoping, Length: 5' - 12', Aluminum, Color: Silver/Green, Tip: Plastic
    Sign, Exit, LED, Aluminum Cast, Black Body, Brushed Face, Lettering Green, 120/277 AC with Battery Back Up, 12-3/4" W x 8-1/2" H
    The first example above just has 12 standing alone, a space before and after.  The second one has 12 followed by a single quote mark.  The third has 12 followed by a hyphen.  All good.
    My problem is:  it DID NOT find this:
    THHN Electrical Wire, 12 AWG, Solid, Green
    I cannot understand why it is not finding this record.  To make it worse, if I change the Description to:
    THHN Electrical Wire, 12 AWG, Solid, Green, 12
    it finds it!  And if I change it to:
    THHN Electrical Wire, 12 AWG, Solid, Green, 12 AWG
    it DOES NOT find it.
    Any ideas what's going on?  I'm baffled.
  • 2.  RE: SQL Server Full-Text search giving me strange results
    Posted 05-03-2022 17:57
    I should also note:
    On the database, ITEM table, Full-Text Index properties, the Full-Text Index Stoplist is set to <Off>.  And I have done a Full repopulation.
  • 3.  RE: SQL Server Full-Text search giving me strange results
    Posted 05-03-2022 20:26
    This is more a SQL Server question than a Maximo one.  I suggest looking at the where clause that is created and see if that generates any ideas.
    Steven Hauptman
  • 4.  RE: SQL Server Full-Text search giving me strange results
    Posted 05-05-2022 12:39
    It's not generating any ideas.  That's the problem!
    This is the Item I'm trying to get it to find:
    THHN Electrical Wire, 12 AWG, Solid, Green​
    So in the Description filter I typed:
    wire green 12
    And it did not find it.
    The WHERE clause this generated is:
    (status != 'OBSOLETE' and contains(description , 'FORMSOF(INFLECTIONAL,"wire") & FORMSOF(INFLECTIONAL,"green") & FORMSOF(INFLECTIONAL,"12")')  and itemsetid = 'ITEMSET1')​
    which looks fine.
    Now if I change the Item's Description to:
    <!-- just adding a comma and then the "word" 12 again at the end -->
    And then I do the same search again:
    wire green 12
    This time it finds it!
    So that makes me think that it doesn't like the AWG behind it.  So I'll change the Item's Description again to:
    THHN Electrical Wire, 12 awg, Solid, Green
    <!-- took the extra comma and 12 off the end, and made AWG lower-case -->
    Now if I do the same search yet again (and therefore the same WHERE clause),
    wire green 12
    it finds it!!
    Why does having AWG in caps after the 12 prevent the search from finding it?  Is there anything I can do about it?  I want AWG there, in caps; and I want the search to succeed in finding it.
  • 5.  RE: SQL Server Full-Text search giving me strange results
    Posted 05-05-2022 13:01
    Interesting.  Can I assume running that SQL outside Maximo and in some SQL editor gives the same result?  If so, perhaps we need to post in a SQL Server forum.
    Steven Hauptman
