Hi Hitesh,
As steven mentioned, there is no way out of this.
If you are trying things in non-prod clustered environment then you can try to run the following query after updating the scripts.
Delete from SERVERSESSION;
There is no issue with running this query on a non-prod environment and it might work for you.
Biplab Choudhury
Tata Consultancy Services
