  • 1.  MXloader New Gen 8.2 Fails with error Message
    Posted 12-09-2021 08:47
    HI ,
    Anyone helps to understand this issue.
    My mxloader version
    when Using mxloader with the below details
    Click Test connection -shows the following message box
    ones click ok the following Error message appears
    Error Message in the Log file :
    2021-12-09 19:08:11 [DEBUG] Parsing JSON
    2021-12-09 19:08:11 [INFO] Error message dialog
    2021-12-09 19:08:11 [DEBUG] Error code : 10001 (10001)
    2021-12-09 19:08:11 [DEBUG] Error source : MxlJson
    2021-12-09 19:08:11 [DEBUG] Error description : Unexpected char in ParseObject
    2021-12-09 19:08:11 [DEBUG] Remedy :
    Is it any seetting are missed in maximo side?
    is it any setting changes need in Network side?
    Can someone please advise on this please
    Rajesh Gajendran
  • 2.  RE: MXloader New Gen 8.2 Fails with error Message
    Posted 12-15-2021 14:01
    Edited by Matt McGuire 12-17-2021 13:59
    Hi Rajesh,
    I had the same error but I recently found Bruno's guide on using REST and API. API Key Authentication MxLoader
    The key is leaving the User field blank and adding the API token to the password field. Conversely, I believe you can add your username, leave password blank, and when you Test connection, an API token is generated.
    Thanks,​
    Matt McGuire
    Aquitas Solutions
