  • 1.  "Sync" Action in MxLoader
    Posted 11-16-2021 16:39
    We have been user MxLoader Version 6.2 for a long time an it's been great.  Just downloaded latest version 8.2(NextGen) and noticed "Sync" action is not available.  Can anyone advise on a work around to perform "Sync" in 8.2?  We use Sync extensively to delete child objects.
    Example:  Yesterday, I had to delete  a number of newly loaded locations ... and to delete locations, they have to have no system/parent association. Tried using lochierarchy delete but our install has customization that threw errors.  Sync of Locations with no child Lochierarchy did the job.
    LEE LE
    Agnira Inc
  • 2.  RE: "Sync" Action in MxLoader
    Posted 11-17-2021 08:55
    Hi Lee,
    What's the customization and what's the error message? I recommend populating your load sheet in reverse order (child at the top) and running a "Delete". I would think that would solve the issue.
    Additionally, if you wanted to delete child records, say jobtasks, invvendor records, or spareparts, I'd create a new OS for those object and delete the record. I use this method frequently when loading inventory with vendor/mfg information. At the end I always pull and delete numerous records in the INVVENDOR table that have incomplete data.
    Matt McGuire
    Aquitas Solutions
  • 3.  RE: "Sync" Action in MxLoader
    Posted 02-14-2023 04:40
    Edited by Manuel Guyot 04-30-2026 08:43
    Hi Matt,
    I try to Delete information in INVVENDOR (MXINVVENDOR) without success, the Result is OK but nothing is deleted.
    Can you explain how you did?
    Thanks.
    MG
  • 4.  RE: "Sync" Action in MxLoader
    Posted 12-16-2021 14:11
    Hi I have decided to remove the Synch action because it is quite dangerous if a user is not really aware of what it does.
    The procedure suggested by Matt is safer and should always work.
    Regards
    Bruno Portaluri (MaximoDev)
  • 5.  RE: "Sync" Action in MxLoader
    Best Answer
    Posted 01-04-2022 10:33
    Hi Lee,
    the Sync option will be available in MxLoader 8.3 that will be released soon.
    Regards
    Regards
