  • 1.  Tagout/Lockout UPload Issue via mxloader
    Posted 09-21-2022 16:37
    Dear All,
    I am trying to upload Tagout/Lockout  records via mxloader.
    whenever i upload Data in system everytime if i re-run the mxloader sheet it will create new record in lockout operations
    My object structure look like this.
    Data get duplicate as highlighted whenever i try to update the existing data
    Kindly help me how to update existing record  in Lock out operations. Not to create new record everytime.
    Nisha Verma
    MDS
  • 2.  RE: Tagout/Lockout UPload Issue via mxloader
    Posted 11-18-2022 13:45
    Hello Nisha,
    You may need to specify an "Alternate Key" in the Object Structure.
    Field Help
    Field:                  Alternate Key
    Table.Column:               MAXINTOBJDETAIL.ALTKEY
    A unique index that the integration framework uses to find a record in the system in place of the primary key for the object. Use an alternate key if the primary key is not known by the external system. Define the alternate key as a MAXIMO index in the Database Configuration application.
    Regards
    Richard.
    Richard Corfield
    RR
