  • 1.  MxLoader Failurelist Query Returns Only 2 Rows
    Posted 12-29-2021 12:29
    I create object structure with FAILURELIST as the only object, no additional settings.  When I run MxLoader query action, only get 2 rows back.
    Anyone see the same behaviour?
    Lee
    System Information
    App Server IBM WebSphere Application Server 9.0.5.6
    Version
    Tivoli's process automation engine 7.6.1.0-IFIX20190404-1532 Build 20180718-1141 DB Build V7610-83 HFDB Build HF7610-02
    IBM Maximo Asset Management Work Centers 7.6.0.4 Build 20180712-1824 DB Build V7604-119
    IBM Maximo Calibration 7.6.0.0 Build 20180718-1141 DB Build V7600-06
    IBM Maximo Asset Management Scheduler 7.6.7.1 Build 20180718-1141 DB Build V7671-16 HFDB Build HF7671-05
    IBM TPAE Integration Framework 7.6.1.0 Build 20180717-1722 DB Build V7610-02
    IBM Maximo Asset Management Scheduler Plus 7.6.7.1 Build 20180718-1141 DB Build V7671-01
    IBM TPAE OS/REST Framework 7.6.1.0 Build 20180718-1141 DB Build V7610-38
    IBM Maximo Asset Management 7.6.1.0 Build 20180718-1141 DB Build V7604-01
    IBM Maximo for Transportation 7.6.2.5-20190415-1043 Build 20180730-2210 DB Build V7625-10 HFDB Build HF7625-07
    IBM Maximo for Oil and Gas 7.6.1.0-20190601-1102 Build 20161020-0803 DB Build V7610-139 HFDB Build HF7610-38
    IoT Connection Utility 7.6.0.1 Build 20180709-1524 DB Build V7601-02
    Server OS Windows Server 2019 10.0
    Server DB DB2/LINUXX8664 11.1 (SQL11014)
    LEE LE
    Agnira Inc
  • 2.  RE: MxLoader Failurelist Query Returns Only 2 Rows
    Posted 12-30-2021 09:54
    I created Object Structure MXL_FAILURECODE with object as FAILURECODE and return all of the records in my system. Is this what you are seeking?
    Stevie
    Stevie Holloway
  • 3.  RE: MxLoader Failurelist Query Returns Only 2 Rows
    Posted 12-31-2021 11:26
    Thanks Steve for helping test ...
    I don't have issues with FAILURECODE object.  I have issues with FAILURELIST  [this is where I load failureclass, problem, cause, remedy]
    Lee
    LEE LE
    Agnira Inc
  • 4.  RE: MxLoader Failurelist Query Returns Only 2 Rows
    Posted 01-03-2022 08:32
    Hi Lee,
    According to an old post by Bruno, it doesn't look like querying failure lists is supported with MXL?
    Maximo Failure List
    If you have SQL access it looks you should be able to query it.
    Matt
    Matt McGuire
    Aquitas Solutions
  • 5.  RE: MxLoader Failurelist Query Returns Only 2 Rows
    Posted 01-04-2022 09:23
    As Matt mentioned, loading is a challenge as you need the ID of the parent object. But in regards to querying, I'm not sure why that wouldn't work. I tested this utilizing the REST API & MXLoader with the REST based option and both are working for me in a demo environment, though I'm on 7.6.1.2 and don't have O&G (which I know extends FAILURELIST). I'd suggest turning on SQL logging for the FAILURELIST object to see what query is getting executed on the server. That might help pinpoint where the filter is coming from to ensure it's not potentially a data restriction or something specific to your environment.
