  • 1.  Delete PO/PR Lines
    Posted 01-20-2022 08:48
    Morning All
    I have been trying to figure out how to delete lines from a PO/PR but have been unsuccessful so far. Our central stores has to get every PR Line approved from the account holder. Normally this isn't a problem, remove a couple of line and everything is good. But every once in a while, someone waits a couple of weeks before approving the PO/PRs and then central stores has to remove multiple lines for multiple PO/PR and look to me to figure out how to do quickly. So I figured MxLoader would be the best option, but so far I haven't figured out how to get it done. Does anyone know if it possible and/or how to go about it?
    Thanks for your help in advance.
    Troy Brannon
    Troy Brannon
    Alcon
  • 2.  RE: Delete PO/PR Lines
    Posted 01-21-2022 09:25
    Hi Troy,
    First, as you know, you generally cannot bypass Maximo functionality so you have to ensure the PO is in a status that's editable. That being said, try creating a new object structure for the POLINE object. Then using MXL to delete those records.
    Matt McGuire
    Aquitas Solutions
