One of the options I always thought that should be built into Maximo is when a user change/updates TARGSTARTDATE on a Work Order the TARGCOMPDATE field should automatically update as well.
I've now had enough of my users make this request that I've started to work on an automation script to do this. However I'm running into the business rule that validates that TARGSTARTDATE is <= to TARGCOMPDATE. So if a user wants to set the TARGSTARTDATE to a future date, the validation is kicking in on save before the the automation script can fire off. If I can update the TARGCOMPDATE before the save kicks in, then the new TARGCOMPDATE should meet the validation requirement?
Is there a method to disable a validation check with an automation script?
OR
Is there a method to update the TARGCOMPDATE before the validation check occurs?
#Administration#Customizations------------------------------
Jason Verly
Agropur
