Seeing the log error is important. You should be evaluating what you see in the DMGR logs like the error message states. You may get a more helpful error message such as not having Java 1.7/1.8 and trying to install an application that requires Java 1.7/1.8. WebSphere 8.5.5 installed 1.6 by default if I remember correctly and Maximo 7.6.0.X required 1.7 or 1.8 and Maximo 7.6.1.X required 1.8.
Which version of Control Desk are you trying to install? WebSphere 8.5.5.3 was the default for 7.6.0.X but you should be on WebSphere 9 if utilizing 7.6.1.X.
Depending on your version of Control Desk, be aware that it can be too large to install normally through WebSphere. See
https://www.ibm.com/support/pages/node/6493689 for alternative methods to install.
Sent: 05-10-2022 06:12
Subject: unable to deploy ear file.
hello,
when i am deploying ear file on websphere 8.5.5.3 on windows 2016 server i got this error.
anybody has face same issue.
syed mehdi
kng
