From what I've read creating an automation script based on a Control ID is relatively difficult.
That being said, you could create a YORN attribute on the WORKORDER object for Complete, then create an Attribute Launch Point automation script that sets the value of the status to complete.
Matt McGuire
Aquitas Solutions
Sent: 07-19-2021 10:27
Subject: Is there a way to change change status icon on Work Order actual screen for Task Section ?
Thanks Matt. yes i also want to change the event action to Complete instead of giving multiple option i want single action Complete
Pradeep Rout
TCSL
Sent: 07-19-2021 10:10
Hi Pradeep,
Change the Event Icon field in the Table Column Properties to:
Are you also trying to change what the action does?
Matt
Matt McGuire
Aquitas Solutions
Sent: 07-19-2021 08:58
Hello All,
I was doing a POC where the requirement is to change the change status icon on work order screen (Actual Tab under task sub section) to Complete workorder icon same as tool bar quick buttons.
Let me know if this is possible as i have tried in application designer and could not find a solution for this.
Pradeep
Pradeep Rout
TCSL
