  • 1.  Unable to add WORKMAN(Assignment Manager) application in Result set portlet?
    Posted 01-18-2021 12:48
    hi guys,
    how can i show the queries on Assignment manager application in my result set portlet?
    #WorkCenters
    Thank you
  • 2.  RE: Unable to add WORKMAN(Assignment Manager) application in Result set portlet?
    Posted 01-18-2021 13:32
    https://www.ibm.com/support/pages/how-configure-result-set-portlet-maximo-76
    Report Object Structure Security may not have been configured properly in the Report Administration application; or, more likely,
    https://www.ibm.com/support/pages/unable-add-group-report-object-structure-security
    Assignment Manager doesn't even have the "Create Report" Signature option, so I think you'd need to add that (compare to another application that does have it. . .WOTRACK has it, at least in my installation.  After adding it as a Sig option, grant that option to your desired Security Groups.
  • 3.  RE: Unable to add WORKMAN(Assignment Manager) application in Result set portlet?
    Posted 01-18-2021 14:10
    I am not even sure you can. Are you getting the error that WORKMAN is not valid when trying to build the result set?
    The value WORKMAN is not valid for Application. Specify a valid value for Application. (BMXAA4191)
    You may be limited to using work order tracking or activities and tasks
