In item master, the part can be flagged as inspection required and then it will always be required. In Purchase Requisitions, at line level, you can check the same box if you only want to require the inspection sometimes, but not always.
So, ITEM.INSPECTIONREQUIRED is the field in item master, and for PR's, PRLINE.INSPECTIONREQUIRED.
Sent: 01-18-2021 10:09
Subject: Adding Recieving/Inspection to a PO
Based on a Inventory and reorder, is there any way to require receiving inspection to that part number based on a purchase request?
Thanks, Jeff
Jeff Snyder
Ford Meter Box Co. Inc.
