Did you check the person record to see of the work dates were modified? Action would be Modify Person Availability.
this would cause the strange view in Assignment Manager where no work assignments are present:
Sent: 09-09-2021 09:46
Subject: Labor availability in Assignment Manager
I am working with assignment manager and have some labor codes that show negative available hours with no assignments. When I change the calendar associate with the labor code the negative available hours change based on the work hours on the calendar. When the same calendar is applied to other labor codes the available hours are correct. It does not seem to mater what date range I select the pattern remains the same. When I select view assignments the window shows none. It appears that somewhere there are assignments or something affecting the available hours. I have looked at the assignment table and do not see any entries for the affected labor codes. Any suggestions on where to look?
Kevin Egolf
TechOps
