We are facing issues while applying fix pack 7.5.0.11 on 7.5.0.0.
Once the install64.bat is executed for the fix pack and provided with current SMP path. we are getting error
CTGIN2462W: An existing E:\IBM\SMP\etc\CCMDBTaskRunnerStore file has been detected. The CCMDBTaskRunnerStore is a list of configuration tasks that must be run to complete the installation. Exit the installation program and run the configuration steps outside of the installation program by using the taskrunner utility. The taskrunner utility resumes the installation at the point where the last successfully completed task was recorded in the previous attempt.
We tried running task runner and it did not help.
currently we just want it to be upgraded to 7.5.0.11 so that we can upgrade it to 7.6.1.
One of the approach was deleting CCMDBTaskRunnerStore and run install64.bat and it did go to the next window but it did throw below error.
Maximo 7.5 No packages are registered as installed. The previous installation is likely incomplete maximo
have anyone encountered such issue before?
Any inputs might help me to resolve this issue.
Thanks in advance!
#EverythingMaximo------------------------------
Pramod Mohite
Infosys
