  • 1.  Network Timeout
    Posted 10-13-2021 13:45
    I keep hitting a network time out and get this in the log, wondering what's not set correctly???
    2021-10-13 12:22:34 [INFO] Error message dialog
    2021-10-13 12:22:34 [DEBUG] Error code : -2147012894 (2147954402)
    2021-10-13 12:22:34 [DEBUG] Error source : msxml6.dll
    2021-10-13 12:22:34 [DEBUG] Error description : The operation timed out
    2021-10-13 12:22:34 [DEBUG] Remedy : Network timeout. Check timeout settings in Config sheet.
    These are the config settings
    Advanced
    Maximum Objects 30000
    Batch Size 0
    Split Child Rows FALSE
    Start Row 3
    Stop On Error TRUE
    Continue Sync TRUE
    Display Query Warning TRUE
    Display Summary TRUE
    Query Only FALSE
    Store Passwords TRUE
    Formatting
    Timezone 0
    DateTime Format yyyy-mm-dd hh:mm
    Date Format yyyy-mm-dd
    Time Format hh:mm
    Logging
    Logging Trace
    Log File Name [XLSDIR]\[XLSNAME].log
    Advanced Connection Settings
    Proxy
    Proxy User
    Proxy Password
    Resolve Timeout 10
    Connect Timeout 20
    Send Timeout 30
    Receive Timeout 600
    OS Service Context Root /meaweb/os/
    OSLC Service Context Root /maximo/oslc/
    API Service Context Root /maximo/api/
    XML Namespace http://www.ibm.com/maximo
    Paul Crocker
    BPU
  • 2.  RE: Network Timeout
    Posted 10-14-2021 12:59
    Hi Paul,
    I notice your Maximum Objects is set to 30000. For the sake of testing, change that to 100 and re-run your query. When I receive the aforementioned timeout error it's because I am querying a large data set.
    Matt McGuire
    Aquitas Solutions
  • 3.  RE: Network Timeout
    Posted 12-16-2021 13:34
    When fetching large result set it is better to use REST service because it fetches only the attributes included in the MxSheet instead of fetching the entire object structure.
    Regards
    Bruno Portaluri (MaximoDev)
