If you're really sure you want to throw the same error for both conditions, simplify it with:
# Declare a variable for the value of the GLACCOUNT attribute
glAccount = mbo.getString('glaccount')
if glAccount is None or glAccount.endswith('-??????'):
errorgroup = 'WORKORDER'
errorkey = 'GLAcctIncomplete'
Otherwise:
if glAccount is None:
# make a different error message for this
errorkey = 'GLAcctIsNull'
elif glAccount.endswith('-??????'):
Sent: 11-19-2021 04:13
Subject: Automation Scripts
Hi Folks
I'm more familiar with SQL than I am python, would appreciate it if someone could help me out with the correct syntax for the bolded section for my automation script, thanks in advance
Cheers
if mbo.isNull("GLACCOUNT"):
errorgroup ="WORKORDER"
errorkey = "GLAcctIncomplete"
else:
mbo.getString("GLACCOUNT") like "%-??????"
Peter McDonald
Prima58
