That error is specific to Service Provider so I assume Maximo for Service Providers is installed in this environment (or an solution like Control Desk/Aviation which includes it). I don't have a demo app currently with SP that I can test this in but I can say we don't use migration manager for security group changes. It's easy enough to just use Application Import/Export by creating a new object structure (in both source and target).
MAXGROUP has to be the parent. APPLICATIONAUTH as the child with the relationship APPLICATIONAUTH. Then you could add the other objects (LIMITTOLERANCE, LOCAUTH, SITEAUTH,SECURITYRESTRICT, etc.) if you need them but if you just need permissions leave it simply MAXGROUP & APPLICATIONAUTH. Then in the More Actions choose "Add/Modify Application Import Support" in the target application and "Add/Modify Application Export Support" in the source application and associate it to either SECURGROUP or PLUSPSECGR (which is the SP specific security group application). Grant the import/export permissions in the Security Group application for the groups you want to be able to do it. Log out of Maximo and log back in and you can now export and import it hopefully.
For clarity, this (by default) functions differently than Migration Manager. Think of migration manager as enforcing things to match verbatim (adding and/or removing permissions) while the default action for application import is AddChange which will add new permissions for example without removing existing permissions. Hopefully this will avoid the issue and be a little easier to manage then creating collections too.
Sent: 03-05-2021 07:44
Subject: How to migrate Security Group application permissions from one environment to other?
Followed the procedure from the Document, But struck with same error.
My requirement is to not Migrate security groups but migrate the Signature Option permissions that are enabled for each application from one environment to another. I don't know if that's even possible to do so! If there's one, will be really helpful to know it.
Harshavardhan Kamepalli
Eidiko System Integrators
Sent: 03-05-2021 02:51
Hi Harsha,
Please refer section 3 in the attached IBM doc.
May be it can help you to migrate the security groups.
Ajay Kotapati
BEUMER GROUP
Sent: 03-05-2021 00:00
We have a requirement to Migrate Security Group Application Permissions from Production to UAT Environment.
For this I tried to make a package from "APPSECURITY" Migration group and deploy the configuration files through "Migration Collection" in the other environment. But, I am getting the error(in the attachment). Even if I select 'Ok', it returns the same error.
I was searching for the issue on google and found nothing.
Any help regarding the issue is appreciated.
