You are able to execute standard SQL statements you want with something like:
<freeform description="What I'm trying to do in the DBC file">
<sql>update mytable set value1='literalvalue';</sql>
</freeform>
When you say PL/SQL, that technically covers all the Oracle syntax but some people refer to it specifically around procedures and such. I've never tried to utilize it to define a procedure, but you definitely would be able to invoke a procedure if it already existed. I assume you've had issues defining the procedures in the DBC file?
Sent: 06-03-2021 07:41
Subject: Pl Sql using in dbc maximo
how to run pl sql using in dbc scripts maximo
Sahil Dutta
xyz
