Maximo JSON API: An IoT Example
  • 1.  Maximo JSON API: An IoT Example
    Posted 06-08-2020 16:56
    I’ve had a lot of conversations recently with folks attempting to implement more Condition Monitoring within their organization. The benefits of shifting from time-based maintenance to condition- or use-based maintenance are well documented and very real. However, making that shift involves a fair amount of planning, analysis, and technology. This article will show an example of how to bridge a small portion of the technology gap; specifically, we will focus on creating meter readings in Maximo via the JSON API available in Maximo 7.6.0.2 and higher.
    Meter readings are the heart of how Condition Monitoring is implemented in Maximo. They represent a piece of data at a point in time associated with an asset. This data could be related to the asset’s condition such as temperature, pressure, voltage, etc. This data could also be related to the asset’s usage such as an odometer reading, the number of cycles of the asset, etc. Lastly, the data could be based on a simple value list such as Pass/Fail, Open/Closed, Blowing / Not Blowing, etc.
    To create a new meter reading via Maximo’s JSON API, let’s start with an example:
    POST http://mxapprove.a3jgroup.com/maximo/oslc/os/mxasset/_QkVERk9SRC8xMTQ1MA==
    maxauth: c21pdGg6c21pdGgx
    Content-Type: application/json
    properties: *
    x-method-override: PATCH
    patchtype: MERGE
        "assetmeter": [
                "metername": "O-PRESSUR",
                "linearassetmeterid": 0,
                "newreading": "4900"
    Let’s look at this part-by-part. First, we start with the HTTP POST itself.
    POST /maximo/oslc/os/mxasset/_QkVERk9SRC8xMTQ1MA==
    This message needs to be an HTTP POST (not HTTP GET). The http://mxapprove.a3jgroup.com/maximo portion of the URL is your Maximo environment’s URL. Substitute that for your own environment’s URL. The /oslc part of the path represents the usage Maximo JSON API. The /os part of the path tells the API that the next part of the path (in our example is /mxasset) will be an Object Structure in Maximo. Finally, the /_QkVERk9SRC8xMTQ1MA== represents a unique identifier for an Asset record that can be referenced in the MXASSET Object Structure. This identifier can be found be querying for the asset using an HTTP GET to the same MXASSET Object Structure, or it can be derived by base64 encoding the asset’s SITEID + “/” + ASSETNUM and prefixing that string with an underscore (“_”) character.
    Next are the various headers.
    properties: *
    patchtype: MERGE
    The maxauth header represents the credentials that are being used to broker the transaction. The value is a base64 encoded string of the format USERNAME + “:” PASSWORD. In an LDAP environment, switch the maxauth header to Authorization and prefix the string “Basic ” to the base64 encoded value. The Content-Type header tells the HTTP request that the body of the message will be in JSON format. The properties header tells the request which fields from the MXASSET Object Structure should be sent back in the HTTP response, with the * character representing all fields in the object structure. The x-method-override header with a value of PATCH tells Maximo that this will be an update to the asset record, and the patchtype header with a value of MERGE tells Maximo to add a new record while keeping the other ASSETMETER records. Without that header, the integration will replace all of the ASSETMETER records with the list in the message.
    Next is the body of the message.
        "assetmeter": [
    Note that we don’t need any identifying information about the asset in the message body, such as the ASSETNUM or SITEID. This is because we are required to specify the unique identifier in the URL string. We specify the assetmeter key as an array of meters associated with the asset. For this example, we are only updating a single meter against the asset (Outlet Pressure). In our object, we specify the Meter Name and New Reading value. The linearassetmeterid key with a value of 0 is necessary due to that field being part of the unique identifier on the ASSETMETER table. Values such as the New Reading Date and Inspector will default based on the current date and the logged in user credentials, but can also be specified explicitly in the message.
    Please feel free to leave questions or comments below. Good luck in your IoT journey!
    See original post
    Alex Walter
    A3J Group LLC
