Just incase others are following and are attempting to change the css files.
When i edited the CSS file in
applications\maximo\maximouiweb\webmodule\webclient\skins\iot18\css\extended.cssrebuilt and redeployed the ear file it did not solve the issue of the font.
the changes were ignored, so I opened up a case with IBM.
The result was a previous
APAR#IJ25347 is out there for the issue
https://www.ibm.com/support/pages/apar/IJ25347
There is an IFIX for 7.6.1.1 link is below.
https://www.ibm.com/support/fixcentral/swg/selectFixes?parent=ibm%7ETivoli&product=ibm/Tivoli/IBM+Maximo+Asset+Management&release=7.6.1.1&platform=All&function=fixId&fixids=7.6.1.1-TIV-MBS-IF013&includeSupersedes=0&source=fc
Will be installing the ifix and testing the changes to the css files again.
updates to follow.
Thanks!
Diane Nohner
City of Minneapolis
Sent: 01-07-2021 09:38
Subject: Work Log and Communication logs changes in work order tracking from Asset Management version 7.6.0.8 to 7.6.1.1
Diane
We have had clients report the same thing. To address it adjusted the extended.css similar to what is descried in this IBM article: https://www.ibm.com/support/pages/apar/IV75207
Once deployed to your Maximo install this does required an ear build and deploy. We have had success deploying this directly to the deployed ear and then restarting the system.
Suggested Change: File:
Addition:
#dijitEditorBody { font-size: 15px !important }
Phil Runion
Projetech
Sent: 01-06-2021 12:36
7.6.1.1 work log in work order tracking
Looking for suggestions on how to address to stay with in our support contract parameters.
Have found articles on how to edit the xml rich text, these are not supported by IBM.
Suggestions are welcomed.
note * Opened a case and were told to open a RFE - this is still and uncommitted candidate.
Also contacted support manager and their suggestion was getting people to vote and comment on it to raise awareness to the issue.
RFE link -
Please vote and make comments -
http://www.ibm.com/developerworks/rfe/execute?use_case=viewRfe&CR_ID=144948
Diane Nohner
City of Minneapolis
