Hi Kevin,
I have leveraged conditional expressions on the job plan labor record to select the row with the planned hours as a function of how many stops are on the route record. The number of stops is populated in a user defined attribute in the PM object. This is the value evaluated during wogen to select the labor that is scaled to the number route stops on the route.
If you need more information on our out of the box configuration, let me know.
Bill Steudler
The Pennsylvania State University
Sent: 06-17-2021 09:22
Subject: PM forecasting
I am trying to utilize the PM forecasting to project resource requirements for the next year. We utilize a large number of routes where some generate work orders as child work orders and some as multi asset /multi loc work orders. For routes with job plans associated with the route stops the cost forecasting appears to be accurate. For the routes using the multi asset generation the cost forecast only shows costs for one iteration of the job plan and not the total cost for the route. We may have something configured incorrectly but I have not found anything to address this. Has anyone determined a way to display this data correctly?
#Analytics
Kevin Egolf
TechOps
