  • 1.  Remove a Shift from a Calendar
    Posted 10-21-2020 17:20
    Is there a way to remove a shift that has been applied to a calendar? The shift turned out to be created incorrectly and I need to remove it and add a different shift. The only thing we were able to find was to just create a new calendar and remove the one with the incorrect shifts.
    #Scheduling
    Anne Antonelli
  • 2.  RE: Remove a Shift from a Calendar
    Posted 10-22-2020 09:09
    You should be able to open that Calendar Record, click on the Work Periods tab, then (if applicable) filter for the shift you want to eliminate.  Then start clicking on trash cans.
    Unfortunately there's no way (from the UI) to do a bulk removal, so if that shift was applied such that hundreds (or thousands. . .) of Work Periods were created, you're going to be clicking trash cans for awhile.
