Hi Silva,
Are you using the correct relationship? Please check whether PROBLEM is the correct relationship between WORKORDER and PROBLEM object. similarly verify FAILURELIST is a valid relationship between the WORKORDER and FAILURELIST object.
You can check in Database configuration application for parent WORKORDER.
If the relationship are existing correctly and still you are getting null , then you may need to check the where clauses of those relationship. Fixing the relationship name and its where clause will fix this issue.
Let me know if you get any luck.
Subhransu Sekhar Sahoo
Tata Consultancy Services
Sent: 03-24-2022 04:26
Subject: Unable to extract workorders with the cause/remedy codes
Hello guys, I need the help from the gurus once again.
Whenever I try to extract workorders with the respective cause/remedy codes, those two fields always come back empty.
Besides other atempts, I've tried these:
- querying (from WO) PROBLEM.FR1CODE
- querying (from WO) FAILURELIST.FAILURECODE
What am I doing wrong?
Silva testes2
testes
