Hi Steve,
Inspection forms are at ORG level, a somewhat annoying feature.
I have tried multiple scenarios and cannot produce the error you have experienced, therefore I look towards the steps leading towards you getting the error.
Q: What status is the form?
Q: Is the inspection form being added to the main body or the task?
Q: What is the sequence that you are adding the inspection form?
ISW
Maximo Practice Manager
eMail:
#IBMChampion2021
Sent: 10-28-2021 09:00
Subject: Adding Inspection Forms to Jon Plan
I am trying to add an inspection form to a job plan and i am getting the following error message: "BMXAA0019I - The Organization field is either read only or part of the primary key. You cannot edit this field." The ORGID and SITEID are blank for this job plan. I can't tell if the inspection form has an ORGID or SITEID assigned within Maximo and I don't have database access on the backend to be able to search the tables. I know there are rules regarding the use of Job Plans within ORGs and SITEs. Are there similar rules for Inspection Forms?
#Transportation
#WorkCenters
Steve Sentz
Sentz Consulting Inc.
