I would recommend getting some middleware to handle the transformations. I use Node-Red. Then you can configure the extract from SAP, transform any data then post into the OSLC api.
Dave S
David Shaw
SRO Solutions
Sent: 09-22-2021 18:16
Subject: Help required to integrate Maximo with SAP Inventory
Hello
I would like to integrate Maximo with SAP system to load SAP inventory data into Item, Inventory, Invcost and Invbalance table using XSL mapping and http end point.
What is the best way to implement this integration?
